Date/Time: Tue, 04 Nov 2025 14:59:30 +0000
*Best* AMP Connection method
View Count: 712
|   [2021-07-19 23:33:06]     |
| User265682 - Posts: 17 |
                Hi there, I hope it's ok to email about this. I have looked through various posts that span the last few months / dating back to last year but I just want to understand the best, most stable method of connecting and trading using SC and AMP. I've read a lot about CQG being buggy with lots of disconnects, has this gotten any better or is it still not very reliable? Is this currently the only option for using Sierra to trade with AMP? I have read your posts about the new SC routing but this also sounds like it doesn't support AMP just yet. Apologies if this has been answered in posts but in my searches I seem to be coming across such a wide array of topics covering the above I'm finding it hard to get a clear cut 'this is the best way' answer. Thank you for your help, much appreciated. Date Time Of Last Edit: 2021-07-20 20:52:26
|   [2021-07-23 07:46:36]     |
                If you are with AMP, you do need to use CQG.  Documentation: CQG Trading Platform Service When using CQG we do recommend using the Denali Exchange Data Feed: Denali Exchange Data Feed Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
