Date/Time: Tue, 04 Nov 2025 10:49:04 +0000
Trial Question
View Count: 523
|   [2021-07-19 17:41:41]     |
| User321000 - Posts: 2 |
                I had created a trial and gotten sierra charts set up before realizing the full learning curve. So with that being done, I never got to really experiment or use the software to see if it is a good fit for me. Is there anyway to restart this trial period or should I just buy a subscription? I thought I saw something to that effect on the trial page, but it has been quite some time.  |
|   [2021-07-19 18:36:56]     |
| Sierra_Chart Engineering - Posts: 21299 |
                Your account has been activated and the usage time extended if necessary. If Sierra Chart is running, it will automatically be activated within about three minutes. However, you may need to exit from the Sierra Chart charting and trading software by selecting "File >> Exit". And then open Sierra Chart through the icon on your desktop or through the desktop Start menu. After your Sierra Chart usage time ends you need to pay for additional usage time through "Help >> Add Usage Credit". Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing  |
|   [2021-07-19 19:50:59]     |
                Thanks a lot for that, can't wait to get into it with some knowledge now :) Have a good rest of your day
