Date/Time: Tue, 04 Nov 2025 10:49:02 +0000
MCL
View Count: 793
|   [2021-07-18 21:40:08]     |
| Marlin46 - Posts: 34 |
                The new MCL mini crude symbol has a "Symbol Settings Not Found for Current Service" Notification on the Chart when pull that  symbol up to trade.  How to remedy that?
                 Date Time Of Last Edit: 2021-07-18 22:06:34
|   [2021-07-19 03:29:54]     |
                We will have to set that up for Transact.
                 Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
|   [2021-07-19 05:30:26]     |
| DGee - Posts: 82 |
                For Amp Futures too. Can’t find it there either.
|   [2021-07-19 08:08:55]     |
                In the case of Rithmic you need to use the new Rithmic connection for the updated symbols: Rithmic Trading Platform Service Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-07-19 08:09:09
