Date/Time: Tue, 04 Nov 2025 10:47:47 +0000
Hide HTF bars in replay
View Count: 543
|   [2021-07-18 21:08:31]     |
| rocketbotx - Posts: 1 |
                I am manually testing a price action strategy (no indicators), using the replay function. I have 6 charts open for M1, M5, H1, H4, H12 and W1. The replay function only works for intra-day time frame. Am am using the strategy from 13 April 2021. On the weekly chart, is there a way to hide all bars from 12 April onwards? Also, why is it not possible for the replay function to work on daily/weekly? thanks  |
|   [2021-07-18 22:34:07]     |
                Refer to: Replaying Charts: Replaying Historical Daily and Higher Timeframe Charts You can set an ending date, for a chart: https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#UseDateRangeFromTo Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
