Date/Time: Tue, 04 Nov 2025 10:39:30 +0000
Denali Data
View Count: 498
|   [2021-07-16 16:33:21]     |
| User744878 - Posts: 2 |
                Hi, How far back does Denali data go, do you have historic futures data that goes back to 1982 for S&P for example when futures was first introduced? I am thinking about getting Denali trying to match my mentors CQG Integrated Client but at a cheaper cost!  |
|   [2021-07-16 19:17:03]     |
| Sierra_Chart Engineering - Posts: 21299 |
                Yes for historical Daily data.   Not Intraday data. Refer to: Sierra Chart Historical Data Service You will also want to create a Continuous Futures Contract chart. Refer to: Continuous Futures Contract Charts Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-07-16 19:17:29
