Date/Time: Tue, 04 Nov 2025 10:44:13 +0000
Order fill connecting line color according result
View Count: 1432
|   [2021-07-16 12:34:49]     |
| Rog3r - Posts: 1 |
                Hello,  i'm trying to modify order fill connecting line color to have green line on winning trade and red line on loosing trade. I've played with "Chart Trading Order fills Entry/Exit Connecting Lines" primary and Secondary and some "Chart trade settings" unsuccessfully. For now, whatever the trade result, the line has the same color as the setting "Chart Trading Order fills Entry/Exit Connecting Lines primary" Google and forum research only lead to how to show order fill line and modify color, but not how to configure it according trades results. Is it possible ? if yes, what option i'm missing or what documentation explain it ? Thanks a lot for your help !  |
|   [2021-07-16 19:11:04]     |
| John - SC Support - Posts: 42737 |
                Make sure that you have the setting for Trade >> Chart Trade Settings >> Order Fills >> Color Connecting Lines Based on Profit/Loss set to Yes. Refer to the information here: Global Trade Settings Windows: Color Connecting Lines Based on Profit/Loss (Global Settings >> Chart Trade Settings >> Order Fills >> Order Fills) For the most reliable, advanced, and zero cost futures order routing, use the Teton service:  Sierra Chart Teton Futures Order Routing  |
