Date/Time: Tue, 04 Nov 2025 10:44:38 +0000
[User Discussion] - Time and sales alert cancellation
View Count: 812
|   [2021-07-16 05:01:40]     |
| Morito_tahiti - Posts: 6 |
                Dear sir, Madam, A few days ago, I tested creation of a sound alert (time and sales price) using "highlight & alert" in time & sales setting window. The test was OK but after cancellation of this test sound alert using "highlight & alert" in time & sales setting window the alert sound still works and after a lot of research, I did't was in a position to cancel this sound alert. Would you please help me to cancel this alert. It's the only alert I tested and used. Kind regards. Maurice  |
|   [2021-07-16 18:43:59]     |
| John - SC Support - Posts: 42737 |
                The first thing is to check the settings from the Time and Sales window (go to File >> Open Time and Sales Window and then select Settings >> Settings Window).  Then ensure that all the settings for the Alert are turned off. The main thing is that the By Field is set to None, but it doesn't hurt to set it temporarily to one of the other options and then set the Bid Trade Alert and Ask Trade Alert both to No Alert Sound, then set the By Field back to None. After that, if you get the alert again, then open the Alert Window and see what it tells you about where the alert is coming from. It would have to be coming from some other place. For the most reliable, advanced, and zero cost futures order routing, use the Teton service:  Sierra Chart Teton Futures Order Routing  |
|   [2021-07-16 19:09:47]     |
| Sierra_Chart Engineering - Posts: 21299 |
                You can determine what Time and Sales window the alert is coming from. Refer to: Alerts Manager: Disabling Alert Sounds Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-07-16 19:10:09
|   [2021-07-16 19:54:19]     |
                Problem solved, I found the correct origin window of the alert. TKS Maurice
