Date/Time: Tue, 04 Nov 2025 10:44:39 +0000
Loading Multiple Studies Collections Into a Chart
View Count: 1454
|   [2021-07-15 22:52:09]     |
| User94606 - Posts: 327 |
                Is there a way to load multiple studies collections into a chart?  In other words, I have 2 studies collections: (1) collection1 of moving averages and (2) Collection2 VWAP and Standard Deviations.  I would like to load these 2 collections studies into a chart and be able to hide/disable the entire collection (Collection1 or Collection2 or both).  I don't want to enable/disable each individual study in the collection.
|   [2021-07-16 16:11:20]     |
| Tonkadad - Posts: 235 |
                https://www.simplesystemtrading.com/hide-studies/ See if this might be of use. I have personally used Frederik for development work and he is a great resource, highly recommend.  |
|   [2021-07-16 19:54:32]     |
| John - SC Support - Posts: 42737 |
                There is not a way to turn on/off a set of Collections. But the Study Collections are setup to replace a set of other collections, by default. Therefore, the idea is that you load one collection and then if you want to use a different collection, you load those and it removes the other ones (essentially, the same as hiding them).  There is also the capability to set a Study Collection to prompt whether to remove other studies or not when it is added. For more information on these topics, refer to the following: Study Collections: Adding a Study Collection Without Clearing Existing Studies On The Chart (Prompt to Remove Existing Studies) For the most reliable, advanced, and zero cost futures order routing, use the Teton service:  Sierra Chart Teton Futures Order Routing  |
