Date/Time: Tue, 04 Nov 2025 10:38:32 +0000
New Account setup question
View Count: 657
[2021-07-15 16:20:29]
RTH - Posts: 2
Hi, I am currently using TT with CME, NYMEX and Eurex exchange real time data and clearing through AMPFutures. I have contacted AMPFutures about trying out your platform and they have said that I have to sign up direct through you. Could you explain to me how I would do this so that I could set myself up to trade live as I do now on those exchanges and what the Monthly costs would be. Am i correct in assuming that I need Sierra Package 10?
Thanks,
Ross
[2021-07-15 17:44:20]
John - SC Support - Posts: 42737
It is not possible to use TT with Sierra Chart through AMP. If you want to stay with AMP, then you would need to change your order routing service to CQG or Rithmic.
The other option is to change brokers and use the Sierra Chart Order Routing Service, which uses TT in the Back-End. Refer to the following information:
Sierra Chart / Trading Technologies Futures Order Routing Service
[2021-07-15 20:50:37]
RTH - Posts: 2
Thanks for the info. I will have a read through the link and get back to you.
