Date/Time: Sun, 04 Oct 2026 21:14:57 +0000
Request to move replay popups into replay dialog
View Count: 775
| [2021-07-15 16:15:21] |
| User660727 - Posts: 50 |
Request to move the replay popup dialogs into the replay dialog itself. Also, persist these values across runs so that I don't have to change them every time I restart the app. Currently the "use start date-time" is not persisted across restart, the "processing step in seconds" value not persisted at all, |
| [2021-07-17 07:27:05] |
| Sierra_Chart Engineering - Posts: 25051 |
We will look all this over.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-07-17 07:27:24
| [2021-07-27 23:30:26] |
Regarding the above, update to the latest release of Sierra Chart. These settings are now fully saved. We still have not worked on implementing the Processing Step in Seconds into the replay window but we will look at that later.
| [2021-07-28 21:21:20] |
I have updated to the "latest release". I'm unclear what "fully saved" means, but the processing step in seconds value does not persist as of version 2291, not even from run to run much less across restarts. I still have 3 popups on the first run, and 2 every time thereafter. The replay module is just awful to use. I get that you've double-down on the 25 year-old UI that is win32, but stop with the damn popup dialogs already! |
| [2021-07-29 00:35:42] |
Ok we will check on this. I get that you've double-down on the 25 year-old UI that is win32, but stop with the damn popup dialogs already! Not sure what you mean with the first part of this. These old dialog windows are getting removed gradually. But we understand what you mean about pop-up dialogs and those will get removed.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-07-29 00:36:13
