Date/Time: Tue, 04 Nov 2025 10:47:09 +0000
Replay speed input field is not editable
View Count: 607
|   [2021-07-15 16:08:18]     |
| User660727 - Posts: 50 |
                The replay speed input field does not work as a input field. The field is reparsed and updated after a small timeout (~500 ms) upon any input, including moving the cursor via mouse or arrow keys.  This should be changed to validation post-focus loss.   The attached GIF show me attempting to edit the field via both mouse and arrow keys  |
|   [2021-07-16 22:03:45]     |
| Sierra_Chart Engineering - Posts: 21299 |
                We will resolve this.
                 Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing  |
|   [2021-07-17 07:29:07]     |
                This is now resolved in version 2287.  Update instructions: Software Download: Fast Update Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing  |
