Date/Time: Tue, 04 Nov 2025 10:47:09 +0000
Is there a way to
View Count: 633
|   [2021-07-15 13:57:30]     |
| User450463 - Posts: 128 |
                On the TPO Profile, I can set the number of ticks each level represents, for example, NQ usually jumps around a lot, so I set the "Letter/Block Price Increment in Ticks" to 8 or 12. Is there a way to do this for a chart with the Numbers Bar study on it? Same reasoning as with the TPO, on NQ and DAX for example, the moves are so large, you're constantly scrolling. It would also be useful on the Delta Profile study, in order to find trapped pockets of traders. Doing this on the numbers bars study itself, or on the chart itself would even be better. Then every study would use the same artificial "tick size". Thanks  |
|   [2021-07-15 14:44:29]     |
| User907968 - Posts: 847 |
                this -> Chart Settings: Volume at Price Multiplier for Historical/Intraday Chart (Chart >> Chart Settings >> Chart Data >> Volume at Price menu)
|   [2021-07-15 15:10:27]     |
                Wow, that is so much better User907968 - thanks a million!
