Date/Time: Tue, 04 Nov 2025 10:47:08 +0000
SC Order Routing service is charging .20 on some trades, why?
View Count: 633
|   [2021-07-15 00:16:52]     |
| User747057 - Posts: 2 |
                Sierra Chart / Trading Technologies Futures Order Routing Service SC Order Routing service is charging .20 on some trades, why? I viewed my transactions and some are .10 and some .20. Thanks for you time. -Kevin  |
|   [2021-07-15 01:31:24]     |
                Specifically on what page do you see these transactions listed? There definitely should not be an issue and most likely you are just seeing  a group of fills being billed in a batch.
                 Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-07-15 01:31:44
|   [2021-07-15 01:52:32]     |
                I was viewing, specifically, UserControlPanel.php?page=TransactionLog. I went back and reviewed by SC trade activity log, I can see now that you did "group" or "batch" some order fills on the SC website TransactionLog. Things seem to reconcile: I see 22 fills in the SC charting application and I see I was charged $2.20 USD. Sorry for the false alarm. Regards, Kevin  |
