Date/Time: Tue, 04 Nov 2025 10:49:02 +0000
Value Area for each candle/bar
View Count: 1012
[2021-07-14 14:15:44]
User330092 - Posts: 9
Is it possible to draw VALUE AREA "High/Low" per each candle/bar, e.g as a box which covered specified area using Number bars studies or volume by price?
Best Regards
[2021-07-14 14:51:15]
John - SC Support - Posts: 42737
Start with the Volume Value Area for Bars study and then try the different Fill styles to see which one you like best. Refer to the following for the study:
Refer to the following for the Fill Draw Styles:
Chart Studies: Notes about Top and Bottom Draw Style Pairs
[2021-07-14 15:24:52]
That was what i am looking for.
Is there option also to see POC per bar/candle but without number bar studies?
[2021-07-14 16:14:17]
Yes, the Volume Point of Control for Bars. Refer to the documentation here:
