Date/Time: Tue, 04 Nov 2025 10:47:45 +0000
Chart on top
View Count: 708
[2021-07-14 12:23:27]
Mattc55 - Posts: 101
I've got two charts that are removed from the main SC window and are stacked on top of each other, but staggered. I'd like one of them to remain on top, but not always on top. when I switch back and forth between workspaces, the chart I want to remain on top, is always behind the one that I want to remain behind it. Is there any way to fix this, without having to set the chart i'd like on top to "always on top"?
thx.
[2021-07-14 13:01:59]
JohnR - User831573 - Posts: 334
The way I fixed a similar issue, was to use AutoHotKey - keyboard macro, and create a macro that selects the workspace you want, then selects the chart you want on top.
Take a look at this thread.
Solved within AHK--> was Enhance 'Goto Chart Number' within the 'Windows' on SC main menu
JohnR
[2021-07-14 13:58:52]
John - SC Support - Posts: 42737
There is not a built-in tool in Sierra Chart to force a specific window to always be above another. The only option is the Always on Top, but as you state, that is not what you want.
