Date/Time: Tue, 04 Nov 2025 10:50:59 +0000
Double candle on the daily chart
View Count: 537
[2021-07-14 07:58:19]
User645832 - Posts: 99
I am seeing a double daily last candle on futures that are not traded overnight (e.g. F.US.GLEQ21), see attached.
I had this issue before using the CGQ data feed and you advised I should switch to Denali, now I am using Denali and having the same issue.
imageDouble candle Daily chart.PNG / V - Attached On 2021-07-14 07:54:42 UTC - Size: 37.04 KB - 198 views
[2021-07-14 09:02:17]
Sierra_Chart Engineering - Posts: 21299
Post an image of the chart following these instructions:
We need to see the region data line at the top of the chart.
We are not able to reproduce this. What happens when you select Chart >> Reload
Date Time Of Last Edit: 2021-07-14 09:04:28
