Date/Time: Tue, 04 Nov 2025 05:43:01 +0000
Changing font size - Vertical line
View Count: 768
|   [2021-07-12 11:44:20]     |
| User417836 - Posts: 11 |
                Does anyone know how to increase the font size for the time shown alongside a Vertical Line ? Thanks.  |
|   [2021-07-12 12:28:57]     |
| 58LesPaul - Posts: 429 |
                Is that text from a study or added with the TEXT drawing?  If text drawing just right click and select hart Drawing Properties and go to Options. Not sure it can be modified from a study unless it can be changed within the study prpoerties.  |
|   [2021-07-12 12:47:18]     |
| User907968 - Posts: 847 |
                https://www.sierrachart.com/index.php?page=doc/Tools.html#ChangingTheFontSizeForTextDisplayedWithToolDrawings%20
|   [2021-07-12 12:48:33]     |
                It is selected via Global Settings - Tool Configs - Vertical Line config - Labels box   Any ideas ?  |
|   [2021-07-12 12:57:27]     |
                All sorted - many thanks everyone !!
