Date/Time: Tue, 04 Nov 2025 14:59:30 +0000
One of my charts not responding to Replay settings
View Count: 610
[2021-07-12 01:59:47]
myke - Posts: 23
When I change replay settings (speed, fast-fowrward, etc), only two out of three charts are affected by them. The third chart's replay settings remain the same as when the replay first started. Help appreciated. Thanks
[2021-07-12 07:14:55]
Go to that chart and then select the Window menu. Is there a checkmark by Window Always Visible.
[2021-07-13 01:25:45]
myke - Posts: 23
Actually I realized that the replay is fine. It's the replay info on one of my charts that isn't updating (i.e., I change speed to 2.0X - on the chart it will still say Replay 1.0x but the chart will still speed up to 2.0x)
[2021-07-23 07:12:46]
Update to the latest version and see if you still notice an issue.
