Date/Time: Tue, 04 Nov 2025 05:42:01 +0000
New instance v second Sierra copy
View Count: 937
|   [2021-07-11 15:23:03]     |
| User97684 - Posts: 136 |
                Hi,  Pls help - i am on highest Sierra package with Denali + Rithmic. I'm already running 5 chartbooks on my only Sierra copy. I'd like to open some more chartbooks, this time with CQG ( diff. acc. ) + Eurex from Sierra. Is it better to install a second copy of Sierra, or run a new instance under File/ New Instance on my current/only Sierra copy? Many thanks  |
|   [2021-07-12 15:09:06]     |
| John - SC Support - Posts: 42737 |
                Since you are wanting to connect to a different trading account, you will need a separate second installation of Sierra Chart. You can get the Denali data into both copies on the same computer without having to do anything special.  Refer to the following: Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service:  Sierra Chart Teton Futures Order Routing  |
