Date/Time: Tue, 04 Nov 2025 05:42:00 +0000
replay help
View Count: 568
|   [2021-07-10 23:25:44]     |
| User431357 - Posts: 27 |
                im with tradepro academy and we use 10 tic, 5 tic, charts along with heat map, footprint , and correlation and non correlation charts . what would be the best options on the replay bar to get a smoother replay, because my charts are jumping and freezing a bit much thank you sc  |
|   [2021-07-12 14:58:46]     |
| John - SC Support - Posts: 42737 |
                Refer to the following: Replaying Charts: Improving Replay Performance / Eliminating Freezing For the most reliable, advanced, and zero cost futures order routing, use the Teton service:  Sierra Chart Teton Futures Order Routing  |
