Date/Time: Tue, 04 Nov 2025 05:42:02 +0000
Does SC support windows 7 64 bit system?
View Count: 895
|   [2021-07-10 01:37:52]     |
| User846709 - Posts: 7 |
                Hi there I really need to know if i can run sierra chart on a windows 7 64 bit laptop as I will be using that system from now on. I have depended on sierra chart for many years for my trading. Thank you  |
|   [2021-07-10 05:26:17]     |
                Yes absolutely Windows 7 is supported. This is the best Microsoft operating system.
                 Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
|   [2021-07-10 15:06:23]     |
                Haha Thank you!
|   [2021-07-11 17:05:44]     |
| User791263 - Posts: 151 |
                Win 7 Pro runs faster-reliably without Win 10 "telemetry", big borders/title bars, forced accounts and huge updates. Reducing to only 34 processes including security- helps speed. Win 7 still gets security updates, maybe some same as Win10. (Must still be a lot of corporate users) Date Time Of Last Edit: 2021-07-11 17:06:18
|   [2021-07-11 22:27:57]     |
                Yes there are a lot of corporate users of Windows 7. Even Windows XP still.
