Date/Time: Tue, 04 Nov 2025 05:41:59 +0000
trailing stop
View Count: 634
[2021-07-09 22:09:44]
User390285 - Posts: 11
can you switch on the trailing stop later when you are already in the trade? would like to switch it on only at the end of the trade
[2021-07-09 23:04:08]
John - SC Support - Posts: 42737
You can use the Triggered Trailing Stop, which allows you to set a trigger level before it kicks. Refer to the following:
Order Types: Triggered Trailing Stop
Or you can send the Trailing Stop as an Attached Order later using the following:
Order Types: Send Attached Orders - Position/Price
