Date/Time: Tue, 04 Nov 2025 05:42:02 +0000
keyboard shortcuts for quickly navigating charbooks
View Count: 1507
[2021-07-09 14:31:51]
User594974 - Posts: 35
Hi, I know I can switch between different charts by using ctrl+tab. However, I'd like to be able to quickly change chartbooks by using a keyboard combination. For instance, I've got 10 chartbooks open, is there a way I can quickly change from chartbook to chartbook without having to click each one separately?
Thank you.
[2021-07-09 16:57:37]
John - SC Support - Posts: 42737
Yes, there are Previous Chartbook and Next Chartbook options under the Window pulldown. These have default keyboard shortcuts of F7 and F8. Refer to the following and the item after it:
Window, CB and CW Menus: Previous Chartbook (Window)
[2021-07-11 20:30:58]
Hi John, this is perfect. Thank you. I apologize that I did not see this. Cheers!
