Date/Time: Tue, 04 Nov 2025 10:44:14 +0000
ACSIL - chart change and data loaded test- sc.SetDefaults or other initialization options?
View Count: 708
|   [2021-07-09 09:42:38]     |
| ATricky1 - Posts: 16 |
                Is there a way in ACSIL of: 1) Testing to see if a symbol has been changed on a chart 2) All data has been downloaded for a symbol on a chart I need to run some code within a study only when both of the above have been fulfilled. e.g. only AFTER a chartgroup chart has been loaded and the data has been downloaded or the chart symbol has been changed and the data downloaded. Thanks in advance. Edit: Reason: If a user drawn drawing (drawn in ACSIL) is, for example, moved mid chart I need it to be always re-positioned beyond the rightmost bar in the chart after the chart load but only as a one off event. After that it can be re-positioned again. Date Time Of Last Edit: 2021-07-09 11:31:03
|   [2021-07-09 15:24:35]     |
| John - SC Support - Posts: 42737 |
                1) Refer to the following: ACSIL Interface Members - Variables and Arrays: sc.Symbol 2) Refer to the following: ACSIL Interface Members - Functions: sc.ChartIsDownloadingHistoricalData() For the most reliable, advanced, and zero cost futures order routing, use the Teton service:  Sierra Chart Teton Futures Order Routing  |
|   [2021-07-09 16:45:09]     |
                Nice one John. Thanks. I just found finally sc.Symbol a few minutes ago but hadn't seen sc.ChartIsDownloadingHistoricalData(). Richard  |
