Date/Time: Tue, 04 Nov 2025 10:39:32 +0000
Setting the time (time zone)
View Count: 2651
|   [2021-07-09 05:52:36]     |
| 2garin - Posts: 188 |
                Good day. Moved to a different time zone, the old value (time) remains in the terminal on the time scale. Previously, the time zone settings were in the data server settings. How (where) can I change the time zone settings now?
|   [2021-07-09 06:15:14]     |
                Refer to the documentation here for this: Time Zone Setting Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
|   [2021-07-09 15:05:47]     |
| John - SC Support - Posts: 42737 |
                The Time Zone settings themselves moved to be their own entry under the Global Settings pulldown menu. Go to Global Settings and you will find the Time Zone option in the bottom right corner.
                 For the most reliable, advanced, and zero cost futures order routing, use the Teton service:  Sierra Chart Teton Futures Order Routing  |
