Date/Time: Tue, 04 Nov 2025 10:44:15 +0000
Why is my data delayed?
View Count: 675
|   [2021-07-09 04:54:56]     |
| Stephen H - Posts: 4 |
                I just topped off the account balance.  I haven't had to do anything beyond that for last 9 months.  Pls advise.  Thank you.
|   [2021-07-09 05:31:00]     |
                You still need to activate the exchanges you require from here: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed What exchanges do you need real-time data for? Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
|   [2021-07-09 15:03:26]     |
                I have to periodically active exchanges?  Again, been doing this for 9 months here, why the procedure change?
|   [2021-07-09 16:59:07]     |
                There is no change in procedure. The reason the exchange was canceled was for this reason: Denali Data Feed: Updated the Auto-Renew status for CMEGROUP_BOOK to (0). Reason: Low Account Balance.
You can reactivate it from here: https://www.sierrachart.com/UserControlPanel.php?page=RecurringServices Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-07-09 17:00:12
