Date/Time: Tue, 04 Nov 2025 10:47:08 +0000
Stock ticker
View Count: 1234
[2021-07-08 21:38:31]
User280589 - Posts: 18
Hello
I have looked through the LSE exchange listed stocks on the SC page and cannot find several stocks. Can you advise how I can find FTSE 100 companies namely British petroleum and Rolls Royce tickers to open a chart.
Thanks in advance.
[2021-07-09 16:36:19]
Sierra_Chart Engineering - Posts: 21299
The symbols are listed here:
https://www.sierrachart.com/index.php?page=doc/SierraChart_RealTime_And_Historical_Symbols.php&SymbolsPage=Stocks&ID=2#LSE
We found one of them:
Description: Rolls-Royce Holdings Plc
Symbol: RR-.LN
Exchange: LSE
[2021-07-12 20:04:53]
Hello
When i search for this symbol in chart settings it is not found
[2021-07-13 01:04:38]
You can also use the symbol search here since we get the data from Barchart.com:
https://www.barchart.com/search?q=Petroleum®ions=eu&assets=equities
We searched for petroleum, within Europe and you can see the list of results.
[2021-07-14 08:05:55]
Hi
I have searched the ticker and found them. the issue is when entering these ticker code in to the SC they are no recognised.
When searching RR-.LN or BP-.LN nothing happens. When searching other stocks eg IAG.LN the chart loads up no issue. Please advise how to proceed.
[2021-07-14 08:53:38]
This should now be resolved.
After that is done:
Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart.
