Date/Time: Tue, 04 Nov 2025 10:38:32 +0000
Adding Stock Indices: Cost Clarification
View Count: 582
[2021-07-08 18:33:10]
ondafringe - Posts: 328
If I want to add stock market indices, in addition to CME, which I am already subscribed, the cost would be $25 + $10.5 in addition to what I am already paying... even though all I want are the indices?
Is that correct?
[2021-07-08 19:01:03]
John - SC Support - Posts: 42737
To be a little more correct, the cost is $25 for the Sierra Chart Exchange Data Feed, plus the cost of the exchange(s) that you want. Most of the index exchanges are $5.25. So we are not sure where the $10.50 came from, unless you are needing two of the exchanges.
Also, keep in mind, the U.S. Equities exchange is NOT the indices. The indices are separate. Refer to the list of exchanges here:
https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SupportedExchanges
And the Setup Instructions can be found here:
https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SetupInstructions
[2021-07-08 19:44:51]
I got the $10.50 from the first link you posted. I didn't see the NYSE indices, so I figured all three major indices would be included with the US Equities for $10.50, although I have no need for individual equities.
NYSE Advancing Issues, NYSE Declining Issues, etc.
[2021-07-08 20:35:38]
If you are looking for the NYSE Advancing and Declining Issues, then you just need to use the Sierra Chart Market Statistics data. Refer to the information here:
There is no charge for these Market Statistics.
[2021-07-08 21:13:49]
Wow... thank you!
That is exactly what I was looking for.
[2021-07-08 23:45:02]
One last clarification:
If I want access to $SPX, then it's $25 + $5.25 (CBOE Indices)?
If I want access to SPY, then it's $25 + $10.50 (US Equities)?
[2021-07-09 13:36:12]
That is correct.
[2021-07-09 13:37:40]
Note that you can get the SPY data (and the rest of the U.S. Equities as delayed data that updates every 20 minutes and is behind the actual time by 15 minutes as a standard part of the Sierra Chart system. Just open a chart for the symbol.
The CBOE Indices, on the other hand, require that you pay for the data in order to get any at all.
