Date/Time: Tue, 04 Nov 2025 10:39:32 +0000
alerts being trigger on order fills?
View Count: 1139
|   [2021-07-08 16:50:58]     |
| User133994 - Posts: 81 |
                Support, Thanks for a great reliable program! Wonderful. So I'm using your "Run Program When This Alert" feature. I have about 7 alerts configured to run 7 different programs based on price movement around indicators. All this works as expected. However, the moment I start trading (simulation right now) whenever I get a "fill" some of the 7 alerts start running the programs? Don't know why...because price action didn't pass the expected indicator...it always coincided with a "fill" whether I am entering a position or getting stopped out. Please let me know how I can stop the excess alert "Run this program.." activities each time a "fill" occurs. Thanks again for all your documentation and quick responses. J Date Time Of Last Edit: 2021-07-08 16:51:45
|   [2021-07-08 17:31:34]     |
| John - SC Support - Posts: 42737 |
                It sounds like you have one of those alerts setup for when an order fills. Refer to the following setting and the 4 after it, and make sure you are not using the same alert number, or turn off the alerts for those items you do not want to alert: Global Trade Settings Windows: Play Alert For New Order (Global Settings >> General Trade Settings >> Notifications) For the most reliable, advanced, and zero cost futures order routing, use the Teton service:  Sierra Chart Teton Futures Order Routing  |
|   [2021-07-08 19:55:31]     |
                Mr John, You are correct. I see the default is to use Alerts 1-7 for various aspects of order fills...I will change those to other alert numbers. Thanks so much. Appreciate your help. J  |
