Date/Time: Tue, 04 Nov 2025 10:44:15 +0000
What is the Problem ?
View Count: 680
|   [2021-07-07 16:31:52]     |
| User562957 - Posts: 58 |
                Hello, what is the problem ? hope you can tell me  |
|   [2021-07-07 21:49:12]     |
                Disregard the prior post. There is some network connectivity issue. We need you to follow the instructions below: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Fully re-download the data in the chart by going to the chart and selecting "Edit >>Delete All Data and Download". After about a minute provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-07-07 21:49:23
