Date/Time: Tue, 04 Nov 2025 10:44:15 +0000
Error creating the service manager object
View Count: 517
|   [2021-07-07 16:13:16]     |
| User660727 - Posts: 50 |
                Since updating to 2284, sierra chart frequently fails to start with error "Error creating the service manager object"
|   [2021-07-07 18:19:17]     |
| Sierra_Chart Engineering - Posts: 21299 |
                We see the condition under which this occurs. We are resolving it now.
                 Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing  |
|   [2021-07-07 18:45:08]     |
                Update Sierra Chart to the current version following these instructions: Software Download: Fast Update This is version 2285 now. Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing  |
