Date/Time: Tue, 04 Nov 2025 10:39:30 +0000
DOM for crypto products
View Count: 1031
[2021-07-07 13:44:06]
User839481 - Posts: 2
I have problem with DOM for crypto products. When I open DOM, change tick size and price display format to good values (for particular product) what I get is mess on bids and asks. How can I configure it (if it is possible) to get the outlook similar to that on the right side on the screen ? I don't want to trade of it, I just wanted to use it to make some DOM analysis. The product in this example is AAVEUSDT-PERP on Binance.
Please see attached comaprison.
Will be thankful for info.
Regards
image2021-07-07 15_32_35-Window.png / V - Attached On 2021-07-07 13:42:27 UTC - Size: 135.8 KB - 274 views
[2021-07-07 14:48:33]
John - SC Support - Posts: 42737
You also need to change the setting for Chart >> Chart Settings >> Advanced Settings 3 >> Market Depth Combine Increment in Ticks. Refer to the following:
Chart Settings: Market Depth Combine Increment in Ticks (Chart >> Chart Settings >> Market Depth menu)
