Date/Time: Tue, 04 Nov 2025 10:38:32 +0000
Maximum historical data
View Count: 650
[2021-07-07 10:17:30]
User39772 - Posts: 311
what is the maximum available historical data based on your equity feed e.g. for symbol AAPL ?
Is there a difference regarding 1-tick data and Non-Tick Data ?
[2021-07-07 10:36:13]
Second Question:
If I start my system test via "Auto Trade System Bar Based Back Test" I can see
all the entry/exit arrows and studies that are used in my system as long as the
test runs. After the test is finished the chart is reloaded automatically and after
that all the information is lost.
How can I avoid reloading after test, so that I can see all the entries/exits etc. ?
[2021-07-09 08:50:49]
Sierra_Chart Engineering - Posts: 21299
1. This is explained here:
Sierra Chart Historical Data Service: What is Included
2. Refer to:
Chart Trading and the Chart DOM: Displaying Order Fills on the Chart
The first step is to make sure the order fills exist in the Trade Activity Log
[2021-07-09 13:49:54]
Thx, regarding 2.
The order fills exist, the problem is, that as soon as the "Auto Trade System Bar Based Back Test" is finished
the date seems to be reloaded automatically. After that, all the system related information (arrows, studies, etc.)
in the chart are gone.
The question is, how can I avoid that the data is reloaded after the test is finished ?
