Date/Time: Tue, 04 Nov 2025 10:44:15 +0000
Data/Trade Service Settings
View Count: 601
|   [2021-07-05 17:56:34]     |
| User221639 - Posts: 3 |
                Hello, i have a approved und funded Account with AMP. Now i got the log in from CQG for real data. When i log in in my SC software und from my control panel i go to File/Data/Trade Setting Service but there is no drop down to choose. its only open a window with" Main Setting", but for me there is no possibility to choose with an drop down window my CQG trading Data. Can you help me please. Regards Pietro  |
|   [2021-07-05 18:46:23]     |
| Sierra_Chart Engineering - Posts: 21299 |
                You must update Sierra Chart to the current version following these instructions: Software Download: Fast Update And here are the CQG set up instructions: CQG Trading Platform Service: Setup Instructions You are on a Service Package with the Denali Exchange Data Feed and that is what we recommend you use for market data when using CQG. But you need to activate the exchanges you require here: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-07-05 18:46:30
