Date/Time: Tue, 04 Nov 2025 10:44:15 +0000
AMP + Denali Exchange Data Feed (data and order placement)
View Count: 1439
[2021-07-05 17:08:47]
User556620 - Posts: 1
I am confused of the different information I could read about trading with AMP futurs as a broker and i am not sure what is actual correct. Please tell me and confirm if I have the correct understanding and if this works:
I consider to start live trading (only CME group) with AMP futures and Sierrachart for charting and for placing orders.
1) I activate the package 10 - standard + denali data feed
2) I order the "Full CME Group (CME, CBOT, COMEX, NYMEX) for nonprofessional Trading accounts" for 3,25 $/month.
3) When I set up the datafeed with AMP, I just have to select "Sierra Chart - Denali - CQG (No Data - Order Routing only" (in the AMP set-up)
4) I have to verify in my SierraChart control panel that I have a funded trading account.
Is this all correct to
a) get real time charting data?
b) place live orders from the dom and charts?
c) trade with sever managed OCO orders?
Many thanks in advance for clarification.
[2021-07-06 15:05:29]
John - SC Support - Posts: 42737
Mostly. Change Step 4) above to 4) Connect to CQG account.
To get setup the way you have stated, once you have the AMP account setup, you should get a set of CQG credentials. Once you have those, then follow these steps to connect your Sierra Chart to that CQG account:
CQG Trading Platform Service: Setup Instructions
Then follow these steps to get the Denali Exchange Data Feed setup for the CME Group data:
Once both of these are setup, then open your Chartbooks and select Edit >> Translate Symbols to Current Service to make sure that your symbols are set to the CQG symbols.
