Date/Time: Tue, 04 Nov 2025 10:38:31 +0000
Using SC-Denali
View Count: 518
| [2021-07-05 16:35:41] |
| bernard - Posts: 14 |
I've just opened an SC-Denali account. But my trading account with Click Futures does not support Denali. They only support CQG. How can I set up and start my SC-Denali account for use with my trading account? |
| [2021-07-05 18:24:11] |
| Sierra_Chart Engineering - Posts: 21299 |
The Denali Exchange Data Feed works with CQG and other Trading services. You can still use it. You do need to activate the exchanges that you require here: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed Here are the CQG set up instructions: CQG Trading Platform Service: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
