Date/Time: Tue, 04 Nov 2025 10:51:00 +0000
[Programming Help] - whay do i get no operator "[]" matches these operands error in Visual Studio Debuding?
View Count: 5515
|   [2021-07-05 13:34:50]     |
| User30743 - Posts: 366 |
                whenever i need to debug some piece of code where there are [] i get this error message no operator "[]" matches these operands https://prnt.sc/18r1m5j How is it possible that [] operator is not supported? i don't get it. How do i get to see the value? it makes debugging almost impossible Date Time Of Last Edit: 2021-07-05 13:37:45
|   [2021-07-05 14:39:57]     |
| User907968 - Posts: 847 |
                Something is wrong with your config, but without more information who can say what it is?
|   [2021-07-05 18:05:10]     |
                Visual Studio config? what more information do u need? this is my solution config https://prnt.sc/18svrwv  |
|   [2021-07-08 15:17:58]     |
| ForgivingComputers.com - Posts: 1153 |
How do i get to see the value? it makes debugging almost impossible The [] Operator in this case means the debugger doesn't recognize the individual array elements. I don't know how to get the VS debugger watch list to let you look at specific elements of an array, or if it is even possible. I asked this a long time ago and got no answer. This is what I do to work around that. Create a persistent variable, assign it to the value of sc.Close[sc.Index] and add the persistent variable to the watch list. You can use a regular variable, but if you want to only break when the value changes, it will always reset each time the study is called. With a persistent variable you won't have that problem. float& ClosePrice = sc.GetPersistentFloat(0);
                ClosePrice = sc.Close[sc.Index];  |
|   [2021-07-08 17:11:17]     |
                Nice catch, hadn't spotted it was being used in a 'watch', had assumed 'autos' or 'locals'.
|   [2021-07-08 17:38:51]     |
| John - SC Support - Posts: 42737 |
                To get the VS Debugger to show the values of an array or vector you can add the following after the variable in the Watch list: + offset, count Where 'offset' is the number of items to skip forward and 'count' is the number of items to display. You can omit the '+offset' and just use the ', count'. For example, if you want to display items 101 - 110, you could add '+ 100, 10' after the variable in the watch list. For the most reliable, advanced, and zero cost futures order routing, use the Teton service:  Sierra Chart Teton Futures Order Routing  |
|   [2021-07-17 11:59:32]     |
                i am sorry, but i dont get it. i want to see this value sc.BaseDateTimeIn[sc.IndexOfLastVisibleBar] -- i get error https://prnt.sc/1c663cz when i write sc.BaseDateTimeIn + sc.IndexOfLastVisibleBar, 1 -- i get another error https://prnt.sc/1c67np7 sow what do i do to make the variable visible? --- another similar issue. i have a SCDateTime variable when i want to see .GetHour() value i get this message -- https://prnt.sc/1c694ig is there any setting i need to do in order to see it? Date Time Of Last Edit: 2021-07-17 12:03:00
