Date/Time: Tue, 04 Nov 2025 10:47:08 +0000
Attached Orders / How to Separate Independently
View Count: 944
|   [2021-07-05 06:18:51]     |
| User371906 - Posts: 141 |
                Hello, Trying to program the following attached orders. This part works good: Step 1 = Stop @ 16 Ticks / Once position is + 20 ticks Move Stop to BE Level Offset 4 ticks Step 2 = Trailing Stop move every 20 ticks Unfortunately, it does not separate the orders and both come into effect at the same time. Question is how to set up these 2 conditions separately, so first will be Step 1 and afterwards step 2 kicks in. Appreciate any input to make these attached orders work together. Thanks  |
|   [2021-07-05 09:09:47]     |
                Your Sierra Chart account which you have logged into this Support Board with is expired.  So we know what Sierra Chart account you are using, go to Help >> Support Board from within the Sierra Chart desktop program. ---- To do this: Step 2 = Trailing Stop move every 20 ticks
 You need to use this particular order type for the Stop Attached Order:Order Types: Triggered Step Trailing Stop This part: Step 1 = Stop @ 16 Ticks / Once position is + 20 ticks Move Stop to BE Level Offset 4 ticks is accomplished by using the Move to Breakeven  for Stop functionality on that Triggered Step Trailing Stop:Attached Orders: Move to Breakeven for Stop Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
