Date/Time: Tue, 04 Nov 2025 10:48:21 +0000
Symbol settings not found for current service
View Count: 501
|   [2021-07-04 22:23:04]     |
| User718737 - Posts: 2 |
                Hi, I am currently on the free trial and trying to test out TPO's on a custom chartbook, however the error 'Symbol settings not found for current service' is displaying. Is this to do with the service package (aware I'll need package 5 or above for TPO's), meaning its unavailable on the free trial? Appreciate any help, thanks!
|   [2021-07-05 02:00:49]     |
                What is the exact symbol of the chart?
                 Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
|   [2021-07-05 10:14:46]     |
                Thank you, it did have a 'real time data' symbol rather than the free trial delayed data symbol, it is working now I appreciate the help!
