Date/Time: Tue, 04 Nov 2025 10:47:47 +0000
Study Number in sc.GetStudyIDByIndex()
View Count: 572
|   [2021-07-04 21:45:29]     |
| Tony - Posts: 640 |
                Hi, I failed to figure out what exactly the Study Number is for any study. It seems that this number is not the same as StudyID used in sc.AddStudyToChart(), neither it is the numeric order in Chart Studies windows. Thanks  |
|   [2021-07-05 04:02:11]     |
                You are not able to see these study identifiers other than through the user interface and that will be added in the next release. You will see them in the Studies to Graph list in the Chart Studies window: Chart Studies: Studies To Graph They will be prefixed with "S_ID:" Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
