Date/Time: Tue, 04 Nov 2025 10:40:27 +0000
Time Line enhancement?
View Count: 602
|   [2021-07-04 14:25:38]     |
| RonW - Posts: 105 |
                Would it be possible to add an input to the Time Line Study to specify a day of the week?  So for example, on a 60 minute chart one would thereby be able to have a vertical line at the first bar of each week. Thanks  |
|   [2021-07-04 15:48:40]     |
| Sawtooth - Posts: 4285 |
                You can do it with the Color Background Based On Alert Condition study. - Set the 'Use Vertical Line Instead of Coloring Background' to Yes. - Use this formula on its Alerts tab: =AND(WEEKDAY(BARDATE[-1])<>2,WEEKDAY(BARDATE)=2) WEEKDAY=2 is Monday. https://www.sierrachart.com/index.php?page=doc/SpreadsheetFunctions.html#WEEKDAY_Function  |
|   [2021-07-04 21:22:17]     |
                Yes, we will get this out in the next release.
                 Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
|   [2021-07-08 03:46:59]     |
                This has been done and released.
