Date/Time: Tue, 04 Nov 2025 10:47:09 +0000
Recenter line on chart trading DOM
View Count: 818
|   [2021-07-03 23:40:48]     |
| AndyB - Posts: 106 |
                I don't know if this is even possible, but I would like to have the recenter line on the chart trading dom not extend on to the chart itself, and I have not seen any documentation on how to do this. Is this doable?
|   [2021-07-04 10:52:23]     |
                The  Chart Trading DOM re-center line in the case of a standard chart should not extend all the way to the left side of the chart. That will be resolved in the next release.
                 Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
