Date/Time: Tue, 04 Nov 2025 10:39:29 +0000
Catching RELEASE_ALL_DLLS
View Count: 658
[2021-07-03 14:05:31]
User79074 - Posts: 105
Would like to catch RELEASE_ALL_DLLS so that i can do proper clean up. Is this feature available or if not can you please do it. Thanks.
[2021-07-04 11:15:05]
Refer to:
ACSIL Interface Members - Variables and Arrays: sc.LastCallToFunction
Make sure you are also running the latest version of Sierra Chart. Must be on the latest version.
[2021-07-05 05:09:52]
That is not sufficient as sc.LastCallToFunction gets called when a study is removed from the chart as well. This is a catch all, which doesn't fit. I need to know when the RELEASE_ALL_DLLS is called.
[2021-07-05 06:05:35]
There is not a way to distinguish that.
[2021-07-07 06:19:29]
Why not? There should be.
