Date/Time: Tue, 04 Nov 2025 10:49:03 +0000
Bulk Property Edit in manage chart drawings window
View Count: 600
[2021-07-02 20:34:07]
User818415 - Posts: 6
Hello, is it possible to bulk edit properties in the Manage Chart Drawings Window? I can edit the property of an individual drawing but that ability isn't available when selecting multiple drawings. Thank you
[2021-07-02 21:01:09]
John - SC Support - Posts: 42737
There is not a way to do exactly what you want.
The one thing we can think of that could save you some time, would be to edit a Configuration for the drawing type to be the way you want, then add that Configuration option to the Chart Drawing Menu (Global Settings >> Customize Chart Drawing Menu). Then you can right-click on the drawing to select the configuration and have the drawing update.
Refer to the following for configurations:
Chart Drawing Tools: Drawing Tool Configuration
And refer to the following for Customize Chart Drawing Menu:
Global Settings Menu: Customize Chart Drawing Menu (Global Settings menu)
