Date/Time: Tue, 04 Nov 2025 10:48:23 +0000
Vertical line time in Candle chart
View Count: 598
|   [2021-07-02 20:11:13]     |
| countryboy92 - Posts: 101 |
                When I place a vertical line on a 3 hour candle it shows me the time for candle open - is there a way to display the time of the candle close?
|   [2021-07-02 20:29:58]     |
| John - SC Support - Posts: 42737 |
                You would have to put that text on yourself as a Text Drawing. Otherwise, there is no support for showing the bar close.
                 For the most reliable, advanced, and zero cost futures order routing, use the Teton service:  Sierra Chart Teton Futures Order Routing  |
