Date/Time: Tue, 04 Nov 2025 10:48:24 +0000
Average Daily Range Time Window.
View Count: 766
|   [2021-07-02 18:36:25]     |
| User628616 - Posts: 132 |
                Is there anyway to get a Avg Daily Range(in ticks) like the attached picture?
|   [2021-07-02 20:00:19]     |
| John - SC Support - Posts: 42737 |
                Use multiple copies of the Text Display for Study and/or Text Display for Study from Chart depending on where you are calculating the data from. Use the Prefix input to create the initial text. Refer to the following: Text Display For Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service:  Sierra Chart Teton Futures Order Routing  |
|   [2021-07-03 13:40:11]     |
                So in the attached pic from 1st message, I need to add 4 Avg Daily Range & 4 Text Display for Study? Also how to display the text/numbers in Ticks and not Points.  |
|   [2021-07-04 11:12:24]     |
                No you just need one Average Daily Range study.  You can compute the moving averages of those with this study: Moving Average - Simple And refer to: Chart Studies: Settings and Inputs Tab >> Based On - Basing a Study on Another Study Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
