Date/Time: Tue, 04 Nov 2025 10:47:40 +0000
Solicitud
View Count: 683
[2021-07-02 15:37:15]
User543464 - Posts: 14
Buenos dias
He querido arreglar mi trade activity log, de manera que inicie desde cero, debido a operaciones que no se cerraban en el registro, despues de haber confirmado con el broker que no tengo operaciones abiertas. Asi iniciarla desde cero. Pero por el contrario, he realizado un desorden en mi registro, el cual solicito me ayuden a solucionar. No se si es posible que ustedes lo pongan a cero desde su propio sistema, hacia mi registro.
Pues ya lei en las instrucciones y no entiendo como hacerlo yo.
Por lo que solicito que ustedes me lo pongan a cero, como si no hubiera hecho operaciones.
Gracias.
[2021-07-02 16:52:50]
John - SC Support - Posts: 42737
From Google Translate:
good morning
I have wanted to fix my trade activity log, so that it starts from scratch, due to operations that were not closed in the registry, after having confirmed with the broker that I have no open operations. So start it from scratch. But on the contrary, I have made a mess in my registry, which I ask you to help me solve. I don't know if it is possible for you to reset it from your own system, to my registry.
Well, I already read in the instructions and I don't understand how to do it myself.
So I request that you reset it to me, as if I had not done operations.
Thanks.
We do not have the ability to reset your Trade Activity Log. That information is stored locally.
Refer to the following for instructions on how to clear the data:
Trade Activity Log: Clearing Trade Activity Data
Then we recommend editing the following setting to set it to a date and time where you know you are flat (right now, from what you state) so the chart will only show fills from that point forward. Note that you will need to set this for each chart:
Chart Settings: Order Fills Start Date-Time (Chart >> Chart Settings >> Trading menu)
