Date/Time: Tue, 04 Nov 2025 10:44:39 +0000
Latency in real time data
View Count: 724
|   [2021-07-02 14:26:10]     |
| User723464 - Posts: 2 |
                Hi, I see real time data with latency of 12 mints. It appears in all symbols. What is the [M] at the right symbol? ESU21-CME[M] Thanks  |
|   [2021-07-05 19:10:21]     |
| Sierra_Chart Engineering - Posts: 21299 |
                The data should be 10 minutes delayed. For real-time data you need to use the Denali  Exchange Data Feed: Denali Exchange Data Feed Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing  |
