Date/Time: Tue, 04 Nov 2025 10:48:21 +0000
LSE data
View Count: 677
|   [2021-07-02 14:15:50]     |
| Manish Thakrar - Posts: 3 |
                Hi I am looking to trade equities on London Stock Exchange. If I use the real time data feed will I have access to VWAP, TPO and cumulative delta? And if so what time frames are available for this data? Thank you
                 Date Time Of Last Edit: 2021-07-02 14:17:10
|   [2021-07-02 15:45:10]     |
| John - SC Support - Posts: 42737 |
                We only have Delayed data for the London Stock Exchange available. You would need to see if the real-time data is available through Interactive Brokers and then setup your Sierra Chart to work with that trading service.  The VWAP, TPO, and Cumulative Delta are all available within the Sierra Chart software as long as you are on the Advanced Package (5, 11, or 12). For the most reliable, advanced, and zero cost futures order routing, use the Teton service:  Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-07-04 11:21:39
