Date/Time: Tue, 04 Nov 2025 10:51:00 +0000
NO data on CQG from Amp
View Count: 506
|   [2021-07-02 08:23:38]     |
| User731133 - Posts: 27 |
                Hi i am unable to receive data feed from CQG on the eurex through Amp , i contacted them and they saying there is an issue on your side can you plese advise, thank you rgds Ale  |
|   [2021-07-02 08:58:27]     |
                Restart Sierra Chart and this will be resolved for the time being. We will come back to you with further details. Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
|   [2021-07-02 09:07:37]     |
                ok working now. thank you
